Front panel layout done
A project log for Open BMS
3-8S Standalone BMS Desing. Open Source Software/Hardware
ben-brownBen Brown 07/08/2017 at 09:450 Comments
The front panel of the unit has been routed and looks to be complete.
This is mostly just a microcontroller with buttons and LEDs.
The plan is to use the 3 switches at the bottom to naivgate and edit the menu, and use the LEDs for status of the system when the lcd is off.
