PL/0 Completed?
A project log for Simple Compiler
A very simple compiler for minimalist home brew CPUs
agpcooperagp.cooper 07/19/2017 at 01:390 Comments
PL/0 Completed?
Brave words! Can it really be completed? There are still things I would like to add but I need to move on. The current state of play is:
  1. Recognises most PL/0 dialects.
  2. Tolerant to redundant ";"
  3. One dimensional arrays
  4. Pascal strings
To do:
Would like to add an ASM instruction (pass through to the target CPU).
Rework the error messages to provide better hints.
Here is an example program:
{ Program Test String }
var Str[16],Prompt[16];
  procedure ReadStr;
  var i,test;
  { Read a Pascal string, uses Str }
  begin
    i:=1;
    test:=1;
    while test=1 do begin
      getc Str[i];
      if Str[i]<32 then begin
        Str:=i-1; { Str == Str[0] }
        test:=0
      end else begin
        if i=16 then begin
          test:=0;
          Str:=i
        end else begin
          i:=i+1
        end
      end
    end
  end;
  procedure WriteStr;
  var i;
  { Write a string, uses Str }
  begin
    i:=1;
    while i<=Str do begin
      putc Str[i];
      i:=i+1
    end
  end;
  procedure WritePrompt;
  var i;
  { Write Prompt }
  begin
    i:=1;
    while i<=Prompt do begin
      putc Prompt[i];
      i:=i+1
    end
  end;
begin
  Prompt:="String Test";
  call WritePrompt;
  putc 10; { new line }
  Prompt:="Enter a string: ";
  call WritePrompt;
  call ReadStr;
  Prompt:="You wrote: ";
  call WritePrompt;
  call WriteStr;
end.
You may notice I have used redundant ":" in this example.
And here is the run:
C:\AlanX\pl0>.\PLZero_Tokeniser\PLZero_Tokeniser     -i test18.pl0   -o test18.token -nl
C:\AlanX\pl0>.\PLZero_Compiler\PLZero_Compiler       -i test18.token -o test18.code  -t  test18.table
C:\AlanX\pl0>.\PLZero_Interpreter\PLZero_Interpreter -i test18.code  -o test18.run   -s  test18.stack
String Test
Enter a string: Hello World!
You wrote: Hello World!
C:\AlanX\pl0>pause
Press any key to continue . . .
I think that is pretty cool!
Next
The next task is to write a P-Code to Subleq translator.
AlanX
