Layout
A project log for The HandyPhone
The HandyPhone is a covert cellphone that you can wear on your wrist.
ivoahIvoah 08/21/2014 at 02:290 Comments
This a slightly out of date image of the layout of the device. I have replaced the flora with a Pro Trinket and moved it from the bottom to the upper enclosure. The mic is also not pictured.
