Which object?
A project log for Sample Keyboard
I want to make a sampling keyboard with the parallax propeller
zuulzuul 08/25/2014 at 02:000 Comments
I think I'm going to try using the KISS WAV player V2 object
http://obex.parallax.com/object/329
and the KISS WAV recorder
http://obex.parallax.com/object/330
by
Kwabena W. Agyeman
there's also a tutorial on playing a wav using prop c code
http://learn.parallax.com/propeller-c-simple-devices/play-wav-files
the mic and maybe amp (maybe just transistor or 386) will be like in this schematic
http://www.rayslogic.com/propeller/DemoSched.gif
the sd card will be set up according to the code ..there are pull up resistors and a regulator on my sd card breakout
design may be modified to a similar one if built into a pcb
I'll use the touch pads on the quickstart board to test
