Custom Motor-Encoder system
A project log for SurgiOS Robotics platform
A modular Robotic Surgery platform which is a more accessible and inexpensive tool to researchers, students and doctors.
Alex KaradimosAlex Karadimos 04/19/2018 at 20:130 Comments
In Surgery Robotics, the most crucial thing is precision of about 0.5 micrometers and also repeatability. Stepper motors are very precise motors but in order to make sure that these always work as programmed and measure each step correctly we also need an encoder. For each stepper motor (double shaft) we use an optical encoder which will measure the shaft's rotation, from the back side of the motor, via a set of gears.
To make that possible we need a component to house the motor, the encoder and the gears. The housing will be 3D printed.
