Mono is a free open-source and cross-platform implementation of the .NET Framework. People argue about which of those two is better. So it’s practically a matter of taste. However, sometimes in order to run some particular app you might need Mono or .NET specifically. In our previous articles we already told you how to use ExaGear Desktop to run Windows applications on Raspberry Pi with Wine and Install .NET Framework on Raspberry Pi. Today we will continue that topic and will tell you how to install the modern version of Mono on your RPi. Below is a simple step-by-step instruction on how to run Mono 4.6.1.3 on your Raspberry Pi. |
Raspberry Pi test stand configuration
Model | Raspberry Pi 2 Model B | Raspberry Pi 3 |
Frequency | 1000 MHz | 1200 MHz |
Memory | 1 GB RAM | 1 GB RAM |
Operating System | Raspbian Jessie from May 2016 | Raspbian Jessie from May 2016 |
Software | Mono 4.6.1.3 Wine 1.8 Eltechs ExaGear Desktop for Raspberry Pi 2 | Mono 4.6.1.3 Wine 1.8 Eltechs ExaGear Desktop for Raspberry Pi 3 |
Mono installation instruction
Install ExaGear Desktop
1. Put ExaGear Desktop archive with installation packages and ExaGear Desktop license key in the same folder. Open Terminal (command line), move to this folder and unpack the archive using the following command:
$ tar -xvzpf exagear-desktop-rpi3.tar.gz |
2. Install and activate ExaGear by running install-exagear.sh script:
$ sudo ./install-exagear.sh |
Launch guest x86 system
3. Enter the guest x86 system using the following command:
$ exagear Starting the shell in the guest image /opt/exagear/images/debian-8 |
Make sure that you’re in x86 environment by running the ‘arch’ command:
$ arch i686 |
4. It is recommended to update apt-get repositories on the first launch of the guest system:
| $ sudo apt-get update |
Install Wine
5. Install Wine in Terminal inside the guest system:
$ sudo apt-get install wine |
Package manager will offer you to install a bunch of packages. Agree and start the installation.
Once the installation process is finished check that you have the Eltechs build of Wine installed:
$ wine --version wine-1.8.1-eltechs |
Install Mono
8. Configure Wine:
Wine can mimic different Windows versions for each application. For Mono version 4.6.1.3 it is requred to set up Windows Vista or higher. To do this run winecfg tool from Terminal:
$ winecfg |
Then in the “Wine configuration” window select “Windows Vista” from the drop down list of “Windows version” field on the “Applications” tab. Click on “Apply” and then “Ok” buttons.
9. Download and install Mono version 4.6.1.3 using Wine:
$ wget http://download.mono-project.com/archive/4.6.1/windows-installer/mono-4.6.1.3-gtksharp-2.12.38-win32-1.msi $ wine start mono-4.6.1.3-gtksharp-2.12.38-win32-1.msi |
Follow the promts and get Mono installed on your Raspberry Pi:
Final notes
Note that with ExaGear Desktop you can install and run plenty of compatible with Wine Windows applications on Raspberry Pi. Here is the Wine Application Database where you can get the information on application compatibility with Wine, as well as tips and trick on Wine configuration for a particular application.
It is also worth to note that with ExaGear Desktop you can run practically any x86 app on Raspberry Pi and other ARM-based devices, such as Odroid, Banana Pi, Beagleboard, Cubox, Jetson, Cubieboard etc.
GET MY EXAGEAR DESKTOP
The original article is Mono on Raspberry Pi
Dmitry
