The test setup for the Kocylator-Engine (Woodward thruster) is ready:
It is a balance scale, capable of measuring with a resolution of 0.0001 grams - theoretically. It´s oscillating around +/- 5mg, but the oscillation is slower than the immidiate forces I measured.
The counterweight is a beer can, filled with scrap metal from the garage. The red box on the left side is used to fine tune the counterweight, because the scale can only handle 50 grams.
I made first tests and measured 10 milligram-force ten times in a row. It´s repeatable and stable.
However, I must test the source of the force.
The force appears immidiately (pointing downward) after the power is switched on, but after a few seconds the force is going upward. When I switch off the cap-HV-oscillator and power only the actuator, the downward force disappears and only the upward force is clearly visible. It´s coming up slowly and decaying slowly after power down, so it´s most certainly coming from the actuator which is heating up.
Further tests will include: Powering only the cap-HV and see if the immidiate downward force arises. If yes, it must be parasitic. If no, hurray. Then I´ll check the forces for different phase angles.
If the results show positive, I´ll ask for a test in Dresden in high vacuum and on a nanonewton sensitive scale.
Here are some graphs of the first tests.
The number seconds on the time axis has to be divided by 5 to get the correct time, because I increased the number of measuring points and didn´t apply the change to the time axis.
Here are the forces without the cap-HV. Clearly a temperature based force, slowly rising and decaying. This is most certainly the reason why the downward force only appears for a short time.
