dimensions of possible solution
A project log for Soft Robotics Modules
A modular design for a soft robotic molds.
Nelson PhillipsNelson Phillips 04/07/2018 at 10:490 Comments
Dimensions of the centre piece connector. This will be the keystone of the design as this will be the part connected to the air supply.
The pockets and dividers for the actuation is designed for use across any actuator.
