What happened so far
A project log for Otto LC
A Laser cut chassis for the Otto DIY robot.
florian-festiFlorian Festi 08/19/2017 at 13:240 Comments
When we decided to do a Otto Bot workshop in early 2017 I drafted the chassis pretty quickly. Although the legs are a bit complicated - the body basically is just a hinged box I already had - it quickly looked like a robot. But only with the workshop approaching got the last details fixed - e.g. the holders for the PCB, the "teeth" holding the head shut, the hole for the main switch, the final size of the ankle screws.
In parallel a group of people was working on a new firmware for the robot and a GUI for moving and calibrating the robot and to create new movement pattern. They currently still lack proper documentation and I have not yet decided whether to make them part of this project here or if they should get their own place - either here on HackaDay or may be just on GitHub.
As a result of this effort the chassis grew an additional mode switch that allows switching between different programs.
We also did building instructions in German with a lot of pictures.
With this in place we did two workshops with 5 kids each.
Lessons learned:
Improvements to the chassis since:
