W1209 Sensor Properties
A project log for W1209 Data Logging Thermostat
The W1209 thermostat is cheap, but it's about time that it learns new tricks!
thomasThomas 08/07/2017 at 06:250 Comments
I made a first write-up about some findings on the NTC and the W1209 sensor input. The datasheet referenced by @jeff1937 doesn't match, and it would be nice to learn more about the particular NTC used for Chinese thermostats!
Edit: I updated the Wiki page above: Chinese NTC sensors sometimes have the tag MFA52AT. I found a datasheet that that describes a typical W1209 sensor pretty well (error within 3%).
Grades of 1%, 2%, and 5% of such sensors are common which means that you one should be careful when commissioning a thermostat for applications where keeping a precise temperature is necessary (e.g. chicken incubator, sous-vide cooking).
