This is the Eclipse Day "Eff Off From Work" Hang Around, View the Eclipse and Hack on Stuff Event - Semi Private
Become a member to follow this event or host your own
Yes, delete it Cancel
You are about to report the project "Bradaki Eclipse View Hackathon", please tell us the reason.
Are you sure you want to remove yourself as a member for this event?
Event owner will be notified upon removal.
