Tubing and irrigation emitters
A project log for Autonomous watering system
This system decides how much water your plants need according to its sensors and internet weather stations and controls a pump to water them
alvaroAlvaro 08/21/2014 at 00:300 Comments
I got some transparent tubes that match the pump's nozzles, as well as some
drip irrigation emitters that I modified so they'd work at higher pressure (I simply cut the inner part that obstructs the inner nozzle).
