Usage Concept
A project log for Trinket Shields
Add-on boards for the Adafruit Trinket M0.
dehipudeʃhipu 09/06/2017 at 03:190 Comments
The following image illustrates how this project might be used:
Yes, you put the shield on top of the development board. If you feel particularly adventurous, you could also put on the bottom, although that won't probably work particularly well with displays.
