LCD
A project log for IRBlack
Arduino compatible IR recorder-replay remote controller with 64KB EEPROM.
amczarnyamczarny 09/11/2017 at 19:050 Comments
The initial prototype had 0.96" i2c OLED 128x64. The main benefits are
on the negative side
The ATMega328P 3.3V will use around 3.5mA. We will have some losses on our Step-Up voltage regulator and other circuits but still 10 mA is a lot.
To reduce power consumption I have decided to move to Nokia 5110 84 x 48
Downsides
The connection requires at least 4  lines + 1 line for led but we will also lose MISO pin as it can not be reused as normal digital pin. In total 6
The LCD is a separate module and can be easily detached from main pcb
