Assembly syntax
A project log for YGREC8
A byte-wide stripped-down version of the YGREC16 architecture
yann-guidon-ygdesYann Guidon / YGDES 12/24/2018 at 07:010 Comments
I have to rewrite the assembler and disassembler... so here is the census of the instructions and their syntax, in order of complexity :-)
This should help structure the code :-) There are 4 special cases to check, and then it's all very orthogonal.
