Improved Shuffling Unit
A project log for YGREC8
A byte-wide stripped-down version of the YGREC16 architecture
yann-guidon-ygdesYann Guidon / YGDES 01/03/2019 at 21:070 Comments
The pressure on the ISA increases and I am already forced to squeeze 2 instructions in the IN and LCDL opcodes. Naturally I'm looking at the shifting/shuffling/barrel shifter and the 4 opcodes.
Things have changed since the last time because the short immediate is now a signed 4-bits field ! This means that an opcode such as ROR can encode both left and right directions, saving space in the opcode map.
SHL, SHR => SH
ROL, ROR => ROT
There are also two other desirable variations :
With Imm4, there is no use for the Imm8 field now as well, which saves another bit. The shifter will use only two opcodes by moving the arithmetic flag/carry flag in the R/I8 flag.
What could these opcodes be used for ? They should remain reserved for now but I can already see the Imm8 extended back to 9 bits for the IN and OUT opcodes, leaving one remaining free opcode slot...
