More (virtual) relays
A project log for YGREC8
A byte-wide stripped-down version of the YGREC16 architecture
yann-guidon-ygdesYann Guidon / YGDES 06/29/2021 at 00:490 Comments
I use circuitjs a lot and I just noticed that it now handles relays. After a great exchange with its author, the relays are now more configurable and can simulate hysteresis !
During the tests, it didn't take long to design a bitslice with the 8 registers and the write circuits:
Having drawings and sketches is nice but making the circuit work is priceless ! Thank you Paul !
Temporary link: https://tinyurl.com/yh8b8ue4
With this many parts, the simulation runs quite slowly. It took minutes to overwrite the 2 leftmost bits but it works as expected !
Adding the read logic is pretty easy at this point but the simulation will be slower.
