The status byte
A project log for YGREC8
A byte-wide stripped-down version of the YGREC16 architecture
yann-guidon-ygdesYann Guidon / YGDES 10/18/2023 at 03:330 Comments
The state of the YGREC8 core is represented by the A1, A2, R1, R2, R3 and PC registers, as well as the three Status flags C, S and Z. Of course, this excludes the memories (instructions and data) as well as all the I/O space registers (some could store bank numbers) but here I focus on the core.
The three flags take three bits and that fits in a byte, with 5 bits left. With the new PF opcode, this free space is now totally used:
1+1+3+the existing flags equals 8, it fits nicely.
This matters not only for the simulator, but also because the core needs to handle interrupts and traps, which requires an accurate snapshot of the core that allows a precise restart.
There are some unused fields in the PF instructions, which might require more bytes to be stored for the next instruction.
