Saving RFID tag into i2c memory
A project log for Bionic Yourself V2.0
Project Bionic Yourself (B10N1C) is a small implant for your arm that makes you a bionic-superhero.
txyzinfotxyz.info 09/29/2014 at 00:300 Comments
RFID Reader/writer IC:  http://www.nxp.com/documents/data_sheet/MFRC522.pdf
Arduino code from my video: https://github.com/txyzinfo/B10N1C/tree/master/Arduino%20Code/RFID_to_memory_test
Сode depends on the libraryhttps://github.com/miguelbalboa/rfid
