eGPU (2016)
External Graphics Processing Unit Enclosure
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
D.I.Y. eGPU SOLUTIONhttps://www.instagram.com/p/BOX1vGBhePD/?taken-by=joel_dittrich_officialNvidia GeForce GTX 1070 (8 GB VRAM, factory overclocked)Akitio Thunder 2 (PCIe v2.0, x16, x4 lane)Corsair CS450M PSU; 450W (paperclip trick applied) - plugged into GPUEdac PSU; 12V, 7.5A - plugged into Akitio Thunderbolt 2 cable - plugged into computer ;-)Used with MacBook Pro (mid 2014, i7 2.5 GHz /4 cores /8 threads) under Windows 8.1 Bootcamp. Result; around 10x, or 1000% better graphics performance, over Thunderbolt v2, compared to internal/dedicated Nvidia GeForce GT 750M (2 GB VRAM), when using external screen.Can (most probably) be used also under macOS with older cards (not only Windows Bootcamp), and/or the newest cards, using the newest drivers. Ordered on 4:th Aug 2016, build successfully finished on 22
