Power Supply
A project log for Electromagnetic Levitation Stabilization Apparatus
This project aims to stabilize objects during earthquakes using electromagnets and an accelerometer.
rishi-salwiRishi Salwi 10/16/2017 at 04:100 Comments
I needed an adequate power supply that could give enough voltage to the electromagnets. I started with a 9 volt battery but this didn't have enough power. I then tried to use a computer power supply. Although, this had enough voltage, it was not safe to use in the long run.
Image result for computer power supply
I then decided to invest in a professional 12 volt power supply. This protected against short circuits and was perfect for my purposes!
