Transformers
A project log for Nixie Tube Power Supply
A flexible power supply for Nixie tubes. Input voltage can be from 3V to 12V. Output up to 200V. It uses commercially available transformers
paul-andrewsPaul Andrews 10/27/2017 at 22:020 Comments
And so began the search for a transformer. I had thought that this would be easy. Specify the turns ratio, inductance of the primary and secondary and power handling capabilities and presto. Sadly, turns ratio seems to be about the last thing you can search on. Unlike inductors, which can generally be searched for like resistors and capacitors, transformers seem to be made with very specific applications in mind, and 'Nixie clock power supply' isn't one of them. When I did find transformers with the right kind of inductance they almost invariably turned out to have a 1:1 turns ratio - isolating transformers in other words. I vented on the nixie clock google group, which is full of exceedingly smart and tolerant people. The kind who would think nothing of winding a couple of transformers before breakfast. I strongly recommend it (the group, that is).
So what was I looking for? This:
Of course, some of these are trade-offs: Small size, high power? Sure.
In the end I scoured the Wurth Electronics and the Coilcraft web sites. Both companies produce a range of transformers that can be wired in multiple configurations - they contain six inductors wound on the same core. I found these on the Wurth Electronics web site. They seemed to be about right, and Wurth were kind enough to send me several samples of each of them. Wurth also have LTSpice models of their transformers - a major benefit that I will get into later.
