Kinda glad for this excuse to finally try the Teensy. The Teensyduino installed easily, and the "button" to upload is easy and fast. I hadn't even realized the 3.5 had Digital Audio, CAN Bus, SD Card, and even ethernet support. Impressive!
Anyway, making the demo code work with it was easy, even with the Hardware SPI.
![](https://cdn.hackaday.io/images/7992811513972322077.jpg)
