Order the Main Board PCB Parts Mounting
A project log for IN-12A Nixie Clock Project
Make a clock with IN-12A nixie tubes.
ho-juneho june 01/28/2018 at 14:460 Comments
I ended up requesting the parts mounting on the main PCB. Perhaps the PCB is likely to arrive in a few days. I'm planning to separate the SMPS from the main board because I want to make a clock that is small, slim, and does not have a lot of heat.
