In this project we are trying to build a very simple but functional 3-trit balanced ternary computer. The only building block allowed is a ternary multiplexer based on DG403 analog switches.
Description of the ternary computer TRIADOR
General purpose
registers
trits 2 1 0 (a trit can take -1,0,+1 values)
R1│ │ │ │ \
├─┼─┼─┤ | Program memory
R2│ │ │ │ | trits 4 3 2 1 0
├─┼─┼─┤ |-- main set ┌─┬─┬─┬─┬─┐
R3│ │ │ │ | of registers a -364│ │ │ │ │ │
├─┼─┼─┤ | d ├─┼─┼─┼─┼─┤
R4│ │ │ │ / d -363│ │ │ │ │ │
├─┼─┼─┤ r ├─┼─┼─┼─┼─┤
R5│ │ │ │ \ e -362│ │ │ │ │ │
├─┼─┼─┤ | s ├─┼─┼─┼─┼─┤
R6│ │ │ │ | s : : : : : :
R7│ │ │ │ | -1 │ │ │ │ │ │
R8│ │ │ │ | 0 │ │ │ │ │ │
├─┼─┼─┤ |-- extra registers ├─┼─┼─┼─┼─┤
R9│ │ │ │ | +1 │ │ │ │ │ │
R10│ │ │ │ | : : : : : :
R11│ │ │ │ | +363│ │ │ │ │ │
R12│ │ │ │ / +364│ │ │ │ │ │
R13│ │ │ │ Special register,
└─┴─┴─┘ specifies memory segment for JP ttt
PC │ │ │ │ │ │ │ program counter register (-364..+364)
C │ │ borrow/carry flag (+1 borrow, -1 carry)
Every 3-trit register can take values from -13 to +13:
t2*9 + t1*3 + t0
where t0,t1,t2 - trits (-1,0,+1)
TRIADOR instruction set
(for lisibility we use N,O,P instead of -1,0,+1)
│op code│mnemonic│ description │
│ NNttt │ EX ttt │ extension commands (work in progress) │
│ NOttt │ JP ttt │ unconditional jump to R13*27+ttt │
│ NPttt │ SK ttt │ conditional skips of the next command │
│ ONttt │ OP ttt │ tritwise unary operation over R1 │
│ OOttt │ RR ttt │ copying between registers │
│ OPttt │ R1 ttt │ write ttt to the register R1 │
│ PNttt │ R2 ttt │ write ttt to the register R2 │
│ POttt │ R3 ttt │ write ttt to the register R3 │
│ PPttt │ R4 ttt │ write ttt to the register R4 │
Additional comments:
- ttt means a 3-trit number with values
from NNN (-13) to PPP (+13)
- RR ttt instruction copies a register to/from R1 or performs
an increment/decrement over R1
OONNN — copy R1 to R13
OONNO — copy R1 to R12
OONNP — copy R1 to R11
OONON — copy R1 to R10
OONOO — copy R1 to R9
OONOP — copy R1 to R8
OOPON — copy R1 to R7
OOPOO — copy R1 to R6
OOPOP — copy R1 to R5
OOONN — copy R1 to R4
OOONO — copy R1 to R3
OOONP — copy R1 to R2
OOOON — decrement R1, set borrow/carry flag
OOOOO — no operation
OOOOP — increment R1, set borrow/carry flag
OOOPN — copy R2 to R1
OOOPO — copy R3 to R1
OOOPP — copy R4 to R1
OOPNN — copy R5 to R1
OOPNO — copy R6 to R1
OOPNP — copy R7 to R1
OOPON — copy R8 to R1
OOPOO — copy R9 to R1
OOPOP — copy R10 to R1
OOPPN — copy R11 to R1
OOPPO — copy R12 to R1
OOPPP — copy R13 to R1
- SK ttt skips one instruction depending on
the sign of R1,R2,R3,R4 or the borrow/carry flag C:
NPNNN - skip if R4 <= 0
NPNNO - skip if R4 != 0
NPNNP - skip if R4 >= 0
NPNON - skip if R3 <= 0
NPNOO - skip if R3 != 0
NPNOP - skip if R3 >= 0
NPNPN - skip if R2 <= 0
NPNPO - skip if R2 != 0
NPNPP - skip if R2 >= 0
NPONN - skip if R1 <= 0
NPONO - skip if R1 != 0
NPONP - skip if R1 >= 0
NPOON - skip if C == N
NPOOO - skip if C == O
NPOOP - skip if C == P
NPOPN - skip if R1 < 0
NPOPO - skip if R1 == 0
NPOPP - skip if R1 > 0
NPPNN - skip if R2 < 0
NPPNO - skip if R2 == 0
NPPNP - skip if R2 > 0
NPPON - skip if R3 < 0
NPPOO - skip if R3 == 0
NPPOP - skip if R3 > 0
NPPPN - skip if R4 < 0
NPPPO - skip if R4 == 0
NPPPP - skip if R4 > 0
Dmitry V. Sokolov
