I hope the majority of the code is self explanatory but feel free to ask if anything is unclear.
The logos are XBM bitmaps stored as strings - I created them in GIMP by saving 16x16 logos as XBM files, then opening the XBM with a text editor and copying the string. You can also use an online converter to make the XBM but that didn't work well for me.
SAYANTAN PAL
Sandeep Patil
I used your code to extend it so the oled could display your current hashrate from nanopool and added some features like offline detection. You can access it on github. https://github.com/o0pwnd0o/miningmonitor
