Hardware
A project log for Cylinder
Machine to drill bronze or aluminum cylinders to be used in the process of microperforation of plastic sheets used in food packaging
jvsalatinojvsalatino 12/19/2017 at 16:510 Comments
The hardware it's the same as the Prusa 3d printer.
Arduino Mega + Ramps 1.4 + Marlin firmware.
Due to the size of the machine I had to use stepper motors larger than the Nema 17 for which the Ramps 1.4 plate (large format Nema 24) was designed. For this reason I have had to replace the drivers of the stepper motors with more powerful ones.
