![](https://cdn.hackaday.io/images/9737071520322873209.jpg)
The Mastech was blazing hot & funding multiple PG&E pensions, so decided to hack the 21 year old AT power supply to generate enough voltage for the Lighting Evers. It now only generated 11V & its fan was broken. It sagged to 10V with the LEDs on. All voltage regulators have a feedback pin.
http://danyk.cz/at_atx_en.html
The internet said pin 1 of the A1K494 was the feedback & these boxes could reach 16V before capacitors started blowing up. It was connected to a nasty resistor network. A 35k was the most likely replacement. Managed to raise the no load voltage to 13.75 but no higher for any resistance above 118k. The 35k seemed to be parallel with a 3k, but whatever. Replaced the 35k with the 118k. With the LEDs on, it sagged to 12V.
![](https://cdn.hackaday.io/images/8285631520322973509.jpg)
Maybe higher voltage could be achieved by returning the 35k & disconnecting pin 1 from the circuit completely. Then provide a scratch built divider for pin 1. It all seemed too much trouble, compared to replacing a single resistor. There might be other issues with over voltage protection & short circuit protection. Any sane lion would just buy a proper supply & wait 3 weeks.
Things were a bit dimmer than the Mastech, but much more efficient. The old fan was relubricated & it worked just like 1997 again. Hard to believe this 235 watter with no insulation on the manes pins & all its sagging was the lion kingdom's very 1st power supply. It powered the very 1st experiences capturing video, something you'd think would require much more.
