Set of 24 parts laid-out on a circular platform: 1x1-24.stl
The simplest cube from the previous log. This time printed. I intentionally skipped the parts deburring to check for +/-0.2mm tolerance promised. Despite some surface roughness, parts stick and click.
After cleanup.
Andrey Kalmatskiy
