Printed sample
A project log for K-raft
A Construction set. Made of flat pieces. 3D-printer friendly.
andrey-kalmatskiyAndrey Kalmatskiy 12/27/2017 at 15:420 Comments
Set of 24 parts laid-out on a circular platform: 1x1-24.stl
The simplest cube from the previous log. This time printed. I intentionally skipped the parts deburring to check for +/-0.2mm tolerance promised. Despite some surface roughness, parts stick and click.
After cleanup.
