Collecting components for high voltage and purchased a Vectrex.
A project log for BUILD an ARCADE XY VECTOR MONITOR
I set out to build a working 13"-27" CRT Arcade XY Vector Monitor. UPDATE!!! 5" and 9" monitors too.
fredkonofredkono 10/03/2014 at 21:050 Comments
I have been collecting components up for the next section of the project the high voltage section. I am still undecided on whether to use a repro wells wg6100 flyback or adapt a common TV flyback. Any thoughts on this would be appreciated.
I also purchased a Vectrex to experiment with. These are a neat vintage vector based games system if you didn't already know.
