Progress: it turns on!
A project log for LED Matrix Controller
A project to control a 32x16 or 64x32 LED matrix with a (beefy) microcontroller
michael-cullenMichael Cullen 03/30/2018 at 22:150 Comments
after my previous failure to solder down the micro controller correctly, I bought a couple of slightly cheaper ones (I didn’t need all the power in the original anyway) and tried again. After some careful work it seems to turn on!
I need to write more software to properly put it through its paces, but so far so good - despite the soldering looking a bit questionable in places!
As to where I went wrong last time, I think the answer is too much solder and not enough patience!
