root access
A project log for Telstra T-Hub rooting/repurposing
This is an attempt to reuse the mostly useless Telstra T-Hubs that are popping up for peanuts in various secondhand places in Australia
theosofttheosoft 04/19/2015 at 13:580 Comments
Full root access ....
rcS has to be modified for that.
for example:
1. getty -L <dev> ; I removed -n and the screenlogin
2. change iptable start to flush
3. enable start of sshd
I also moved the t-hub stuff in /etc/rc.d/init.d/ to a folder "disable".
So these service are not started
