Another option for the output stage
A project log for Bat Sonar
Bat like sonar sensor that can track multiple targets and estimate angle of arrival using chirps and cross correlation in near real time.
filip-mulierFilip Mulier 02/04/2018 at 11:420 Comments
TI makes a combined boost converter and amplifier for piezo applications.  Its called the DRV2700.  Using this would reduce the parts count a bit, including reducing the resistors needed in the current opamp circuit.  Will need to consider for future prototype.
