Connect your Feather HUZZAH ESP8266 to Ubidots
A project log for Connect your Feather HUZZAH ESP8266 to Ubidots
Learn how to setup your Adafruit Feather HUZZAH ESP8266 with Ubidots
Maria Carlina HernandezMaria Carlina Hernandez 01/11/2018 at 15:380 Comments
The Adafruit Feather HUZZAH ESP8266 is an 'all-in-one' ESP8266 WiFi development board with built in USB and battery charging.
The Feather HUZZAH has an ESP8266 WiFi microcontroller clocked at 80 MHz and 3.3V logic, able to be programmed using the Arduino IDE for an easy-to-use Internet of Things applications; click here for additional specs for the Feather HUZZAH ESP8266.
In the following tutorial, Ubidots will demonstrate how to setup and program the Adafruit Feather HUZZAH with ESP8266 using the Arduino IDE to display data with Ubidots.
