Boards arrived
A project log for ZeroCool
An active cooling solution for the Orange Pi Zero
Chris SlothouberChris Slothouber 01/11/2018 at 17:100 Comments
Received boards back from OSH Park this week. Checked for mechanical mating to ensure measurements line up with the host board. Everything checks out okay, though the top mounting holes are not quite big enough for M3 screws. Thankfully nylon screws are just forgiving enough to be pushed through with a bit of force.
To-do: assembly & bring-up.
