Y axis bearing blocks completed
A project log for Simple DIY laser cutter
Basic laser cutter than can be made with standard shop tools.
philphil 03/07/2014 at 22:140 Comments
I have just finished the Y axis bearing blocks.  These support the metal rod from the stepper motor that hold the gear that moves the gantry.  I made these with 10mm HDPE on my CNC.  HDPE is fantastic to work with!
