Some of the IR controlled devices I have are in a different room. Ive been sketching a way to use the RF from the main Beacon to communicate with a small IR Attiny85 node that would translate an RF signal into an IR code and transmit it.
A project log for Ultimate Universal Remote
Improving a Griffin Beacon to add Bluetooth RF control, Command sequence sending and USB power
