updated firmware, faster baud rate
A project log for Cypress PSOC 4 + ESP8266 WS2812 RGB XMAS Lights
802.11 WIFI enabled RGB LED Strips, using the ESP8266 and $4 Psoc 4 dev board.
charliexcharliex 10/29/2014 at 06:260 Comments
Changed to the v0.9.2.2 AT Firmware.bin firmware, set the baud rate to 230400 and now i'm pushing out 150 leds at 10ms intervals. looking nice. I'll keep increasing the baud to see how far i can go.
firmware update is just CH_PD high, GPIO0 low and run the update tool via the UART, i have an echo mode on the PSOC so it can proxy the uart and update the firmware.
