Simple windows UDP send
A project log for Cypress PSOC 4 + ESP8266 WS2812 RGB XMAS Lights
802.11 WIFI enabled RGB LED Strips, using the ESP8266 and $4 Psoc 4 dev board.
charliexcharliex 12/24/2014 at 17:090 Comments
Here is a very basic UDP send to one node at a time. Make a simple win32 project and copy this in. (Also added to github)
// simple_udp.cpp : Defines the entry point for the console application.
// Headers (put this in stdafx.h if using precompiled headers)
#include <stdio.h>
#include <string.h>
#include <stdlib.h>
#include <winsock2.h>
#include <Ws2tcpip.h>
#include <conio.h>
// Library needed
#pragma comment(lib, "Ws2_32.lib")
// Defines
#define LIGHTS        L"192.168.1.230"    // Address of Node
#define BUFLEN        ( 450  )            // Length of data to send to LED strips, 150 LEDs, three byte values per LED , 450
#define PORT        (40002)                // The port the ESP is listening on
// short cut exit routine
void die(const char *str)
    fprintf(stderr, "error: %s\n",str);
    WSACleanup();
    // exit with error
    exit(1);
int main(void)
    WSADATA  w ;
    struct sockaddr_in si_other;
    int s, slen = sizeof(si_other);
    unsigned char data[BUFLEN];
    /* Open windows connection */
    if (WSAStartup(MAKEWORD(2, 2), &w) != 0) {
        fprintf(stderr, "could not initialise winsock\n");
        exit(0);
    // create a udp socket
    if ((s = socket(AF_INET, SOCK_DGRAM, IPPROTO_UDP)) == -1) {
        die("socket create error");
    // setup the target port/address
    memset((char *)&si_other, 0, sizeof(si_other));
    si_other.sin_family = AF_INET;
    si_other.sin_port = htons(PORT);
    // convert IP address string to numerical
    if (1 != InetPton(AF_INET, LIGHTS, &si_other.sin_addr)) {
        die("InetPton failed");
    printf("press space to stop\n");
    // wait for a key press
    while (!_kbhit()) {
        // fill the buffer with a simple blue fade
                // each LED is three bytes, RGB, so the 2nd led is (index*3)
        for (int i = 0; i < BUFLEN; i+=3) {
            data[i  ] = 0;        // red
            data[i+1] = 0;        // green
            data[i+2] = i>>1;    // blue
        // send to ESP
        if (sendto(s, (const char*)data, BUFLEN, MSG_DONTROUTE, (struct sockaddr *) &si_other, slen) == -1) {
            die("couldn't sendto");
    //get rid of keypress (fflush)
    _getch();
    closesocket(s);
    WSACleanup();
    return 0;
