More Blue Smoke
A project log for Pico-Kubik quadruped robot
The tinniest Arduino quadruped robot.
dehipudeʃhipu 12/23/2014 at 14:244 Comments
Today is a sad day for this project.
I decided to use a new battery that I bought specially for this robot, instead of using battery packs from my Walkera RC helicopter. Taught with previous mistakes, I have a socket for the battery that only lets you insert the plug the correct way. Being assured by this, I didn't really look carefully when I connected the battery... Alerted by the hissing and smoke from the power switch, I immediately disconnected it but... too late.
What happened? Look at this:
See? Battery packs from different manufacturers have the plugs in reverse... I suppose that increases their sales.
Unfortunately, this time not only the power switch is fried -- also the VoCore. The Arduino Pro Mini and the camera module seem to be fine, though.
Jarrett wrote 12/23/2014 at 21:08 point
This project log should be called "No more blue smoke".
Because you let it out. All of it.
deʃhipu wrote 12/23/2014 at 21:33 point
Well, I do have another VoCore, and a spare power switch, so there is some still left. Hopefully it will stay in there a little while longer.
davedarko wrote 12/23/2014 at 20:57 point
Noooooo :( I've had some similar experiences once with a power connector soldered backwards on a controller board for my 3D printer... One thought - rectifiers everywhere would be awesome. No color coded cables anymore.
deʃhipu wrote 12/23/2014 at 21:34 point
At least the LiPo didn't explode...
