Test Board for ESP-201
A project log for ESP8266 Development PCB's
Development board for ESP8266 the make up of which can be decided by the community
Michael O'TooleMichael O'Toole 10/11/2015 at 04:102 Comments
Just in case anyone wants a test board based on the little white ESP-120 Module, here's some ideas... (KiCad)
The board can be used for testing and programming the ESP-201 module... It's pretty much the same as a board I found when googling but aimed at testing inertia sensor using the ADC... All files available on request...
The unit is powered by USB and contains a Buzzer, RGB Led and a Piezo sensor...
The USB circuitry (CH340B) is under the ESP201 (little white board module).
Note my design for the sensor, it's a standard inexpensive piezo disk modified to greatly enhance it's performance when used as a sensor... the design can out perform sensors costing many tens of dollars...
I managed to replaced a $34 sensor with a $2 sensor and small weight connected to a piece of wire soldered to the disk... Additionally, if the weight is resting lightly on a surface (such as a window or door frame), vibration is transmitted directly again greatly improving detection...
Updated version:
includes on-board SD reader, USB to Serial CH340B, AtMega328, Inertia sensor for AD testing etc... Will probably redo this for through-hole as it's easier to build... I've yet to test it so don't be surprised if I screw up and I have still to add the TFT for debug...
Michael O'Toole wrote 10/15/2015 at 23:52 point
Thanks Dave... my right hand is 200 micro seconds faster than my left.... aka my fingers are dyslexic :D
davedarko wrote 10/15/2015 at 16:07 point
your title says borad :)
