Good results with this test, 1218 Angstroms of intensity counts @ 532.15nm CW (center wavelength)
FWHM @ 3.9nm
The medium I used was Isopropyl alcohol, 99.9% lab grade purity thru a standard 1cm quartz cuvette.
A project log for 3D Printable Raman Probe
This a 100% 3D printed Transmission Raman Probe (low resolution) W/built-in cuvette holder/Raman filter
FWHM @ 3.9nm
