Slick Button Placement
A project log for Super Basic Tony Stark Costume
Arc Reactor to wear under other clothing.
dhgoldbergdhgoldberg 12/01/2014 at 03:440 Comments
You can solder a small tactile button directly to the Trinket from 3V (or 5V) to Pin 1 and the LED circuit will act as a pull down. Helpful for reducing wiring in a simple and quick project like this one. Inspiration from here (see bullet 2): https://learn.adafruit.com/tap-tempo-trinket/things-learned
