• 1
    Step 1
    Step 1: Cut out the wooden panels
    Cut out the wooden panels you will need to assemble the shelf for the circuit and speaker. The image above will show you what you need to cut. If you want a print out template, we've included a PDF you can download below.
  • 2
    Step 2
    Step 2: Start Gluing
    Glue the panels A, B, and C together as shown in the assembly graphic. When you add the shaft collar, make sure that the set screw is facing the back of the shelf. A couple of pieces of double sided tape will help keep the shaft collar in place while you are gluing.
  • 3
    Step 3
    Step 3: Glue Togetehr the Servo Mount
    Next, glue two of the D strips together to create a .5" x .5" x 2.75" block. Repeat this with the other two D strips. When they are both dry, glue them to the back of panel A as shown in the assembly diagram. The space between the two pieces should be the width of the servo.
