Z-axis falling-prevention AKA Stepper-shorter
A project log for 3D Printed Repairs
For "Repairs You Can Print Contest", and for the sake of documenting the repairs and improvements, done by 3D printing.
christian-lercheChristian Lerche 06/17/2018 at 06:300 Comments
One of the guys in the Danish 3D DIY facegroup asked for a solution, for his original Ultimaker bed.
It moves quite easy when not enabled, or when power is disconnected.
Same problem I have seen online, with the Cetus 3D printer, where a printed part was used.
My solution is:
Short out the stepper, when power is disconnected, or the driver is disabled.
This is done using a regular DPDT relay, and (if you're using drivers with !ENABLE) a MOSFET/Transistor.
I'm working on a schematic for most uses, and also a PCB.
But the fun thing is in the relay:
When the coil is energized, the stepper lines go through the relay, to the output.
When power is disconnected, the relay goes back to NC, and shortens the stepper.
I just need to work on the driver-circuit for this, so the enable stuff will work.
Have a nice one!
