This is again one of the older projects/repairs.
My wife's aunt came to me, as the caravan center told her, that she couldn't get a replacement for the locking mecanism, for the blinds. These things break. At least when the caravan is 20 years old.
So after taking some pictures with a caliper on the part, a new was sketched up (I used sketchup back then, pun intended).
![](https://cdn.hackaday.io/images/9018271516567899116.jpg)
It was printed in PLA, which will probably not hold up to the temperature in the caravan, but in not-so-sunny Denmark, it is not much of a problem.
Two of these goes in the mount, with a spring in between. She said it fitted like a glove.
