LCD testing with the Teensy
A project log for 1337 3310 tool
An hacker's swiss knife in the form factor of the best phone ever
Mastro GippoMastro Gippo 01/06/2015 at 22:040 Comments
...and it works! Other than more memory and more power, the Teensy also has two PGAs on board and two separated 16bit A/Ds that should help to improve significantly the original design. Well, the hardest part of the project is already done, now on to the porting!!
