Trinkets arrived
A project log for Multimeter remote display
Multimeter remote display using a wireless link
ken-kaarvikKen Kaarvik 12/05/2014 at 01:510 Comments
My trinkets arrived so I just had to try out a couple of things that I had running on an 8MHz mini pro clone.
My transmit unit uses the softseral function but won't work on my 12 MHz trinket. I guess I'll use hardware serial.
My code that boots up a GameBoy Advance works with no modification. I'm also working on a display unit that will be more "pocketable". I'll probably have a couple of different versions with different displays.
