Mounted!
A project log for TTTOTP
Tiny Trinket Time-Based One-Time Password
colonwqcolonwq 01/02/2015 at 22:070 Comments
I have mounted the board on an Adafruit Permaproto Breadboard sized for an Altoids can. This was my first time using one of these boards.
I have learned a few things:
  1. Don't run the wires from point to point. Routing is better.
  2. Mind the soldering iron shaft. I scorched a couple of wires.
  3. Get more colors of wire. Yellow, yellow and yellow are not enough.
  4. Test mount everything with stacking headers. If it all works, remove the headers
